Hello again, more Decades/H&I troubles
Ok I took the plunge and finally flashed my microHD with the June 6 th file (latest) to be able to receive all the channels that are closely spaced (4 khz) . This was supposed to fix the problem where Decades would suddenly start pixelating and turn into H&I, that is why I loaded this latest file, otherwise I never would have bothered as I was extremely happy with the Jan 1 file I have been for the longest time.
Now as I am recording the Dobie Gillis binge I noticed the same trouble and quickly caught it by temporarily going to the menu and back to stop the 'morphing'. I am an electronics technician so understand how drift (caused by increased temperatures here now) can cause the local oscillator in the lnb to cause the receiver some confusion - again the tight spacing of only 4 khz ! I have an older lnb and I am sure the specs are woefully out of range by todays standards.
Do you guys and gals think a newer Norsat will do the trick or should I do some more investigating.
If I get a chance I want to spray the electronics with refrigerant to see how much it fluctuates - later when I do some annual tune up work.
In the meantime enjoy the Binge !!
T
T
