Lightning Strike
ChrisK114
1,051
4
Mount Pleasant,SC
This weekend I had lightning strike about 20 fet from my house. I lost my Directv signal. I have a slimline dish with a 6X16 multiswitch. The switch is inside my structured wiring box. The green light is off on the switch so I am assuming the box got fried by the strike. Is there anything else it could be? This happened Sat night and the soonest D* can send anyone out is this Saturday. I was just wondering if there is something simple that I could check. Thanks. I have checked the plug and that is okay.
Find out where it is plugged in at and see if its damaged/un-plugged/on a gfci circuit/on a blown breaker. Also if you have an older Multiswitch (6x8) you could use that temporary till a replacement can be delivered. Also double check with Customer Support and make sure they note on "tech instructions" to bring a replacement 6x16 as its not normal in truck stock.
Zinwell WB68 Multiswitch ???'s
Looking to make change, need info please!
