Put up my new H24 in our cabin, and lighting came in on it. Did not knock out the tv, only receiver. I heard it pop and saw it. I had just hooked up to the new slimline. Is there anything I can do in the future so this will not happen again.
On my house the metallic conduit that feeds the meter has a grounding rod bonded too it. My OTA antenna and FTA dishes are connected to that. Make sure you use a substantial copper wire as the conductor. I believe I used bare #8 solid copper wire that was purchased from Home Depot. I measured out how much I needed and they cut the wire to length and charged me by the foot. Don't forget to ground your coax too as required by code. Click the link below for some visual aids.I mean appreciated.
Along with proper grounding mentioned by others you might add one of these inline where the coax connects to your equipment. I have them on all my satellite and antenna leads. A little extra protection can't hurt.Put up my new H24 in our cabin, and lighting came in on it. Did not knock out the tv, only receiver. I heard it pop and saw it. I had just hooked up to the new slimline. Is there anything I can do in the future so this will not happen again.
For a SWM system I would expect the power supply to be more susceptible to damage than the receiver for a nearby strike.
