Today I drove my 12 Ft Mesh Dish over to 123.0W on C Band, then I hooked up my Sat Meter to try and bring in 123.0W on Ku Band. I discovered that if I LIFT and HOLD the bottom Lip of the Dish I can see 2 of the strong Tp's on 123.0W.... that is: 11700, and 11800 with Quality of approx 20%. You really have to lift up on the Dish. Adjusted Elevation up about 2 full threads and after tightening my newly installed Bolts & Nuts on the Dish I still couldn't pull in 123.0W on Ku - but S = 68 now on 11700 and 11800 where previously the best I could get it was about at S = 65. This was done after Peaking the Actuator 10 to15 clicks from East to West inside the House to see if I could fine tune for 123.0W on Ku Band. Went back outside and even with the Mount Bolts Tightened up I could still pull the Dish up and see those 2 Tp's until I let the Dish go, just couldn't move it sideways from East to West.
What is the Best way to proceed here, - that is keep adjusting Elevation UP even more or should I look at Declination as well?? Any replies would be much appreciated.
