I have MRV (all white DECA) and can do VOD, PPV, YouTube, and Pandora. My setup connects to my Router via a Switch by means of a white DECA box. I was installed in 2010. Is the CCK just a fancy DECA module?
Yes. The Cinema Connection Kit is also known as a DECA BB, which not only adapts your internet signal from your router to travel over the coaxial to the receiver, but also bridges that signal to all of the other receivers in your MRV setup. The HR34 has this hardware built-in. Other receivers will disable MRV if you plug an ethernet cable into them.Is the CCK just a fancy DECA module?
Nope. No difference.So it offers no additional functionality over the white DECA box installed for me.
You can. I did. One less thing plugged in, one less splitter on the line, and fewer wires tangled up behind your home theater. What's not to like?But if the HR34 will function as the CCK why not ditch the white DECA CCK?
I didnt simply because of the distance from my router to my HR34.. woulda been a long run of Ethernet cable, and I'm lazy when given the opportunity
