Ok, so I used to have a setup with an HDTV in the main room with coax stretching from the 722 box to a 2nd SD TV in the bedroom. Just got a 2nd HDTV now for the bedroom. At the moment, I just hooked up the coax to the back of the 2nd HDTV.
Now I understand I can only get one HD signal, and it'd only go to the main TV, correct? There's no way of having an HD signal on the 2nd TV when I'm not using the main TV?
Next, the 2nd TV seems zoomed in on, I've got it set to 16:9 but for instance, a cable channel's watermark in the lower right corner is always cut off. Any way to make the ratio right, or is that just because its standard def?
Finally, what about DVR'd HD programming and OTA local HD channels on the 2nd TV? Is that possible? In the setup, the local channel setup is grayed out on the 2nd TV, and the DVR programs are also in standard def and cut off like the regular programming is on the 2nd TV.
Thanks for any answers.
-Scott
-Scott
