I know we have numerous threads about Hopper+ with Joey4, but I thought this deserved a new one since it specifically does NOT include the Hopper+. If the mods think it should be in one of the other threads feel free to move it.
I just upgraded my (3) Joey 3's to Joey 4's. I retained my original Hopper3 and did NOT add the Hopper+. Just FYI -- Dish requires a Tech visit since there is some new ATV files that need to be downloaded to the H3. If you are a customer in good standing you can probably get the charge for the visit waived (I did), other than that there are no upgrade fees. Here are my quick thoughts so far (Tech just left about an hour ago).
PROS:
CONS:
Overall the upgrade is nice for the speed improvement, but I'm not sure I can recommend it because of the removal of some of the old features, as well as incompatibility with the 40.0 remotes. We'll see how my family likes them over the next few weeks and I'll report back.
PROS:
- J4s are MUCH faster than the J3s, especially in the Guide.
- Text/image resolution in the menus is MUCH sharper.
- Picture quality seems to be slightly better as well.
- They have an option for PiP (but I haven't gotten it to work yet).
CONS:
- J4s only give you the Android menu as a start/home screen. There is no way to go the old start screen that had all the settings. There is also no way to change what the box does on startup (like Go To Last Channel or Go To Home Screen). So if you like the Android tiles you are fine, but without the H+ your H3 will still have the "old" menu (which my family likes better) while the J4s will have the Android menu. So could be some confusion within the household.
- There is no way to jump quickly to the old Settings menu. You need to scroll to the gear icon in the upper-right corner, then scroll through the dropdown on the right, then find the Device Preferences, then go to the correct dropdown to get to the full Settings screen.
- While the J4s have native bluetooth, you MUST turn it on and off. On the J3s I could have my BT speakers paired but turn the volume down/off at a switch on them, then use the TV volume. If I wanted to use the speakers I just turn their volume up and the TV volume down. With the J4 you must enter the BT menu (which takes more clicks than the old Settings menu due to point above), then Pair the BT accessory. When you are done you need to remember to Unpair or you won't get any volume out of the TV speakers.
- Some other settings are not even available anymore. You can't see/manage Caller ID history, you can't change screen format to add/remove borders on SD broadcasts, and some other minor settings are missing.
- The 40.0 remotes are NOT compatible!! This may not matter to some but may be a deal-breaker for others. You can get some of the functions to work, but major ones like the Menu button, Format button, and Cancel key do not work at all (and there are others like Page Up/Down in the Guide, misc). The Cancel one makes it impossible to back out of menus or DVR listings, and without PU/PD you can only scroll one line at a time in the Guide. So if you are okay with the 5x-series remotes you are good, but for those of us that love the 40-series it will be impossible to navigate some of the major menus.
