J3 over Ethernet
TheKrell
A mighty and noble race originating on Altair IV.
39,105
47,141
Fairfax, VA
Back when I first got my H3 with 2 J3's, I experimented with one of them by unplugging the coax but leaving the Ethernet connected. After some chaos and confusion with the network settings, it worked great! Fast forward to today when I experimented again. No joy no matter what I reset.
Is there some magic setting that I should have used to get this going, or is that now prohibited? IIRC it's on J537. Maybe 536.
I have a J2 working over ethernet right now. That J2 used to be hooked up via coax years ago until I moved a J3 into that location. I simply activated the J2 and plugged ethernet from the Hopper 3 directly into the J2 and it works fine.
I actually got to thinking about it and unplugged my ethernet cable from the Hopper to the J2. Then I plugged a short ethernet cable between my LAN hub to the J2 and that worked too! Of course the Hopper is also plugged into the same LAN to get internet.
I unplugged the coax and left the Ethernet which is (through switches) able to communicate to the H3 on the same LAN. It never reconnected to the H3, despite restarting it and resetting the network numerous times. I didn't do a power plug reset, though.
What am I doing wrong?
Try the power plug reset first. If that doesn't get it don this:
Temporarily move the Joey to the Hopper 3 location. Place an ethernet cable from the Joey to the Hopper. Power up the Joey and it should connect to the Hopper. You can check this by powering up the Hopper. Press Home 3 times on the remote. Go diwn to Whole Home. You should see all the receivers connected including the Joey you just connected directly to the Hopper. If you do, bring the Joey back to its original location and hook it up. You should link up to the Hopper provided your ethernet is connected to the same LAN the Hopper is.
So... You are saying that I should use a crossover cable between the Joey and the unused Ethernet jack on the Hopper? Interesting ploy. I'm trying the power plug first.
Exactly what I am saying.
Well, that worked. The (actual regular) Ethernet cable from the upper port to my J3 resulted in it pairing just fine. So the Ethernet jack still works. But I tried the following (after unplugging the coax) with no joy whatsoever.
  1. Reset the network.
  2. Soft reset J3
  3. Power plug reset J3
  4. Soft reset H3
  5. Tried Dish USB WiFi adapter (not visible from J3)
  6. Bridging was on. Turned it off.
In all cases the result is DHCP failure, no valid IP address, and no communication over that Ethernet jack although I do see link and flashing traffic lights. It's as though DHCP has been disabled through software. Looks like Dish killed this option which worked fine before. :crying
  2. Soft reset J3
  4. Soft reset H3
Did you try a standard CAT5 cable, not a crossover?
  2. Soft reset J3
  4. Soft reset H3
That's just the top port? Or both?
Sorry for my delay in posting this. I'm having numerous issues with my new house, including my 2X mortgage auto-pay that mysteriously got turned off. Fortunately I caught that snafu in time.
Yes; that's what I tried. I didn't try the crossover cable because I couldn't find it easily. Since it worked, then we know that the Ethernet jack on the J3 and my regular cable are fine. DHCP is not fine on my regular LAN.
Just the top port. Since it worked, I saw no reason to swap. The H3 is on my LAN via the bottom port. This very setup did work years ago when I first got the Hopper.
Considering Jumping
International Channels on DISH via Satellite is no more
