johncop said:Just got an h10-250 Tivo, will it be mpeg4 compatible? Thanks all. Also, I have a wide screen TV, how come some of the HD programming fills the screen and some does not?
slacker9876 said:The debate is actually over, yes they could update them with a combination of firmware & software, however, DirecTV will NOT be doing this.
However, you agree the debate is over and that new HARDWARE will be used. So you made this argumentative post why? Like I said, the debate is over, let's not quible for the sake of making one another look bad. The end result (on topic) is that his HR10-250 will not be docoding MPEG4.Hogarth said:I would strongly disagree with this statement.
All MPEG decoding is done in hardware, not firmware, not software.
There is an MPEG-2 decoder chip inside each and every DirecTV receiver.
Even the new NDS box isn't capable of MPEG-4 without the addition of a separate IC coprocessor chip. There's nowhere on the TiVos to install this chip, nor was the TiVo designed to accept one in the first place.
http://www.conexant.com/products/entry.jsp?id=911
slacker9876 said:However, you agree the debate is over and that new HARDWARE will be used. So you made this argumentative post why? Like I said, the debate is over, let's not quible for the sake of making one another look bad. The end result (on topic) is that his HR10-250 will not be docoding MPEG4.
