With a recent software upgrade for the R15-300 DVR, DirecTV has added more remote codes for newer TVs, including Vizio.
Unfortunately, 4 of the 5 codes that are listed for Vizio cannot even be programmed into the remotes that I have. I have tried both the RC23 and RC24 remote models, and the results are:
10864 10865 11499 11758 : rejected by the remote; that is, there is no confirming double-blink after the 5th digit, and no change in the previously-programmed setting. What's up with that? Is there a newer model of remote that these codes are supposed to work with?
11756 *is* accepted by the remote, but it doesn't happen to work with my particular Vizio (P42HDTV) model.
BTW, the code that does work (kind of) with my Vizio is 10178, which is one that I found by luck and hard work, and which isn't even listed in the DVR's choices. I say "kind of" because the "TV Input" option does not work with this particular combination of remote code and Vizio model; basically, all I have ever been able do with the RC23 and/or RC24 is control the TV volume, mute, and On/Off.
