Internet Connection Issues
How to setup wirlesslan openvix.Press menu/setup/network/device
How to setup wirelesslan openPli and satdreamgr.Press menu/setup/system/Expert settings/Network
Click ok on Wlan connection
Click ok on Scan wireless networks
Click ok on your wireless network
Use interface, press right or left arrow, set to Yes
Set Encryption for the network router/gateway. (Unencrypted),(WEP),(WPA), (WPA or WPA2),(WPA2)
Add Encryption Key.Use the number key pad and each press of a number changes the character.
Example If you need a 2 press 2 four times. Need a 0 press 0 one time.Need a lower case n press 6 two times.
There is a Character box on the screen that looks like this.
1= 1 . : ; + - * / = _ @ # $ % &
2= a b c 2 A B C
3= d e f 3 D E F
4= g h i 4 G H I
5= j k l 5 J K L
6= m n o 6 M N O
7= p q r s 7 P Q R S
8= t u v 8 T U V
9= w x y z 9 W X Y Z
0= 0 , ? \ [] () ~
Once Encryption key is entered press ok and yes to activate the network.
just did sda_ setup, almost worked, if u right click on ecryption key, it will bring up new line asking for " hex" or "ascii" i used -ascii - to enter key code, then arrowed up and changed "ascii" to "hex" then ok and yes, works.
using mio with tnap , if using wlan u get one ip address, if using lan u get a different ip address, so write them down, webif works with ip address.
Reactions: primestar31
