Hi.
I'm having some technical difficulties installing a dish at my vacation home, where I'm currently at. I was hoping to get some advice from the experts around here. Here's my situation.
Main Home:
Dish 500 with Quad LNB
3 receivers connected (322, 508, no phone lines anywhere)
Boston locals
Vacation Home
Dish 500 with Dual (not Twin) LNB -- it has separate heads, so I assume it's the dual, not the Twin.
311 receiver, no phone line
Switch 21.
Ohio
I think I have the Dish pointed well. I aimed it by setting the Point Dish tool to 119, T19, and maximized the signal. It shows about 110 signal rating for ODDs and EVENs which seems good.
Then I switch over to 110. I get the ODD T's, but no EVENS. I've run Check Switch. It identifies the switch as a quad 500. That can't be right. I've done the front panel reset, the power off, reset to factory defaults, all without luck.
My cable run is about 12' from LNB to Switch, and about 80' from switch to receiver. I've shortened the receiver to 6' with the same results.
From what I've read on here, it seems that this setup is best when you match equipment at both homes -- is that my problem? Should I just get a quad LNB? But I've also read that missing the EVEN's usually means a cabling issue / connector issue. But all cable is new RG6.
So I'm at a loss here. If I get 119 ODDs/EVENs and 110 ODDs, does that mean my Dish is pointed correctly? What do I need to do to force it to recognize that switch? I've also swapped out that switch with another one, with the same results.
Thanks for any help.
Main Home:
Boston locals
Vacation Home
Switch 21.
Ohio
