Avoid the SG series.....been through a few of them since 2008....Like Brian said not sure of pedigree.
It would be great if you could motorize the 39" for better signal. Then you could use the 36" as a fixed dish. Maybe post up a few picks of the 39" to see what you need to make it complete. Someone may have the part or know where you can get it low cost.![]()
Good that they made it right for you.The 39 dish is a WorldTV dish, see: http://www.hypermegasat.com/World TV Dish.htm. Spite the pictures id didn't come with any mounting hardware. I can't complain b/c when they were informed that I got the wrong dish, they sent another that arrived within a few days. I'm not sure yet but I may need to put the 36 inch dish up about a foot or so so I can get an adequate swing for a motor installation, do they extension tubes? or what should I call it?
But be aware that the HH120 is much slower than the HH90 (I have both).
Be aware that the diameter of the HH120 shaft is 54 mm - whereas the HH 90 is 42 mm, so a small dish may not fit on the HH120 shaft. I had to make a custom bracket to fit my 85 cm dish on it.
With regard to rotation speed, the HH90 is 2.4 degrees per second on 18v (horizontal TP), or 54 seconds for the full 130 degrees maximum arc of these motors. By comparison, the HH120 is 0.7 d/s, or 3 minutes and 5 seconds for the 130-degree arc.
For 13v (vertical TP), the HH90 is 1.5 d/s, or 1 minute 27 secs for the full arc, and the HH120 is 0.4 d/sec, or a staggering 5 minutes 25 secs for the full arc.
Clearly, the HH120 requires patience, being over three times slower than the HH90!
Regarding the tab on the dish mount, simply bend it out of the way to get it on the HH90 shaft.
In any case I've doubled the number of satellites we receive. We get two now. I couldn't find 72W so I went back and found 97W, tweaked it, and then went back to 72W and it was there!!! What's the best way to permanently mark everything so if the wind moves something I can put it back to where it was? Spray paint?
Nail polish also works great to cover screw terminals to prevent corrosion. Can't recall where I first heard about it but I put some on my antenna rotor terminals quite a few years back and when I took it down for upgrades last year they looked like new under the polish.I borrowed a bottle of mamas' red nail polish.Easy to see on the black pole.Not sure how long it will last.
She wasn't too happy when I used her nail files for rust removal though.![]()
