herky said:masterdeals, did you peak your dish using 119 or 118.7? What kind of meter were you using? In the June 30 Facts Blast, DISH receommends peaking using 118.7 and that it will require a new sat meter for certain states:
"Applied Instruments is introducing a new meter called Super Buddy. This meter should be considered for installations in the following states: Washington, Oregon, California, Arizona, New Mexico, Texas, Louisiana, Mississippi, Alabama, and Florida. "
For all other states a Birdog is recommended.
Yes, it's there. I misread your original post. I was looking for a pop up message.masterdeals said:The message I was seeing is on the "Details" screen after you run a check switch. Take a look and let us know if you see it too. It's the message in post 4 of this thread that we are questioning.
boomerang said:Hey masterdeals, what do your get for installs?
I'm in North Oakland County. I have to get up at 3:45AM for work, so no late night upgrades here!
Alvn8r said:not to be picky but you need some better fittings and some weather seals wouldn't hurt. are any of your connections corroded??? little things like that will give you trouble that is hard to trace.
You also need to change those Low Frequency ground blocks, the DPP44 switch can burn those out very easily.
Kirby Baker said:I'm curious, with all the storms that have come through the area lately, have you tried to see how the rain fade is on 118K and 129 with the new dish?
ralfyguy said:masterdeals, could you do me a favour and measure the rectangular tubing size of the arm, and the distance from the 129 lnbf to the center of the dish. Im thinking about a new project....
The same applied to me on my old 1000. My elevation was supposed to be 42, but 44 increased ALL the signals significantly!masterdeals said:I found a slight increase in elevation versus the book number worked best for me here in Michigan. It was around 1-2 degrees.
