Sat 103 Transponder(s) 15 & 23 for HDWhile we are talking about moving, what TP is Philadelphia Locals on?
If you are moving arcs, then yes that is a problem. If you have the correct satellites for your moved DMA, just tell them or message DIrT and have them update your satellite configuration on their records.I am having nothing but problems with moving. I spent over 2 hours on the phone yesterday with D* CSR's, only to be told that, even though the system takes my new address, I don't have the right dish to receive my new local channels. Is this a common problem? Would it be possible to have some on this board contact me via email? I very discouraged at this point.
Does directv have a Dirt team now?If you are moving arcs, then yes that is a problem. If you have the correct satellites for your moved DMA, just tell them or message DIrT and have them update your satellite configuration on their records.
I guess I'm not sure what satellites I need. I moved 30 miles due south from one state to another.If you are moving arcs, then yes that is a problem. If you have the correct satellites for your moved DMA, just tell them or message DIrT and have them update your satellite configuration on their records.
when did Directv get 2 arcs?If you are moving arcs, then yes that is a problem. If you have the correct satellites for your moved DMA, just tell them or message DIrT and have them update your satellite configuration on their records.
Bottom line unless you are in the spot beam of the locals you are trying to receive, you won't get them.I guess I'm not sure what satellites I need. I moved 30 miles due south from one state to another.
Thought it was a dish forum. My mistakewhen did Directv get 2 arcs?
So tell us which market you are in and what market you are trying to get, and you can look up the TP map to see .
Well unless you have SD only equipment I see no reason any HR with any slimline couldn't pick up either of those, Since they are both either on the 99 or 103.I'm in Harrisburg locals right now and want Baltimore locals. I am 5 miles north of the Maryland line. D* had me do a bunch of things on the receiver (including changing the satellite type) and finally came to the conclusion that I don't have the right satellite to receive those locals.
They haven't use that Sat in years.Well unless you have SD only equipment I see no reason any HR with any slimline couldn't pick up either of those, Since they are both either on the 99 or 103.
Unless Directv is still using the 72.5?
Hey Scott, didn't you say they were tossing that idea around? They have an Internet team on social media, they won't come over here?I wish!
Rick Esenwine, I just checked the charts, both Harrisburg and Baltimore have their sd locals on 101, so it seems that what the csr told you is wrong.
