Earl over at DBStalk once again has the scoop.
http://www.dbstalk.com/showthread.php?t=69545
Several fixes. Hopefully the key one for me is the searching for satellite signal will be eliminted - a huge problem on MPEG4.
It says that this is a staggered release - may be a little while to get it without a forced update.
Here is the release notes from over at dbstalk:
Program deleting from the MyVod before user action or delete criteria reached (space, SL settings, etc).
Prioritizer will remain in-sync with the todo list
Upon initial playback, content doesn't play and displays "DELETE" On-Screen Dialog
Additional Miscellaneous fixes (no specifics provided)
Improved accuracy of hard drive usage indicator
'Searching for satellite' message no longer appears while viewing a recorded program.
Improvements to Manual Recording Scheduling and reliability
Additional stability fixes
Improvements to HDMI compatibility.
All A/V Outputs are disabled when the unit is put in standby mode
Unofficial Support: eSATA will properly reflect full size of connected drive (or RAID)
