I have an HR-21 and want to know if once I connect it to my home network if it will play MKV files off of my computer? Can you use the HR-21 as a Media Center Extender with Windows 7?
I don't know if Media Center will stream MKV files, but I was successful in setting up TVersity and getting HD MKV file to stream to my HR-21. If you try it you need to change the default video resolution from 640x480 to something higher. You may also have to disable the media streaming function of media center.
Thanks a lot.
Do you know if TVersity will play 1080p content and also support 5.1?
It will depending on how fast your processor is. You can set it to pass through the audio without changing it to get 5.1. It will take a powerful processor to transcode 1080p on the fly. I am running on a 2.6Ghz Quad Core, but I have only tried 720p content. It handles that without a hitch.
Did you try having Tversity down convert the video to 720p and see if the HR22 would play the file then? It simply may not be able to handle it.
I was able to get a 720p file to play on my HR21, but it only played at 480p. I know it was streaming 720p because I could view the stream on another PC and it was fine. I think the HR21 can talk to Tversity and tell it what it is capable of. It may only be able to handle 480p. I'm not sure.
Media Playback Device was set to Auto
Video 1280x720
I have a wired connection between them.
I couldn't get any video with AC3 audio to play correctly either. It was always garbled.
Found some more info about the limits of HR2X and media share from another forum.
Here is the catch -
You can set it up resize limits 1280x720 and it will work
Then you have to setup TVersity to 'downconvert' it to 854x480 - the HR2x will choke on the higher resolution.
Sounds like there is no chance of HD through an HR2X box.
