How to lift a 300 lb schedule 80 pole yourself.
I woke one morning with the idea how to lift my long schedule 80 pole into its hole without help. Even with help it would almost be impossible. My dad, in his day, invented a wall lifter for house building. It has been leaning against the shed for 15 years. It worked effectively. Once I was able to erect the scaffolding around the partially raised pole, standing on the scaffolding, I could hand push the pole into the vertical position. If you are a small guy, having a friend would really help pushing it into the vertical position. Afterwards, with a length of strut, I could push the base of the pole into the center of the hole. Photos attached. Next I will install the rebar and then call a concrete truck.
