How to disconnect an EHD on H3
MIshler
52
8
ontario,ny
I've been experimenting with a second EHD and have experienced system lockups/crash. I've figured out that it happens within hours of removing the drive, not connecting it. I have been disconnecting by turning the system off and unplugging the drives USB cable. Any ideas of a different procedure? A red button boot recovers it but is annoying.
Sent from my Nexus 10 using the SatelliteGuys app!
I have, for years, simply unplugged the EHD from my still hot receivers, 722, H1, H3. I never had crashes after that. When I unplugged the EHD I would get a slide that said it was removed. When I plug it back in the slide recognized that it was plugged back in.
I have 4 EHDs connected to an USB hub. The USB hub is connected to the H3 3.0 USB port. My Pioneer AV player has a AC plug. The 4 EHDs are plugged into that AC plug using a 4 outlet power cube. When I turn on the AV receiver the 4 EHDs are powered up. I can have 3 of the 4 USB ports active at one time and the H3 sees them. So I see 4 Sources on my H3 DVR 1 for the internal drive and the 3 EHDs. When I shut down the system I use the remote to shut the H3, the TV nad AUX for th
new install this morning H3, joey X2, 2.0 or 4k ??
Upgraded to H3, EHD now needs to reformat after 4 days
