How many 'steps' in one degree of movement?
The spreadsheet reports the degrees of movement the motor must move. This is not the same as difference in azimuth along the horizon. The axis of the motor is parallel to the axis of the earth, no matter what your latitude is. In the top-down view, you are looking down on top of the earth's axis, as well as the axis of your motor.
To exaggerate the angles as you used them, think if you are at 84 degrees west at the equator. Your azimuth from 83 to 85 would be 180 degrees. The real difference in position as seen by a motor is only ~2.x degrees.
Thanks all!
pspitael,
I'm sorry, but I'm sure I gave you some inaccurate data!
The idea was good, but the calculations I gave you were flawed.
The motor rotation speed information was correct, but the distance it had to move was not calculated properly by my method, so sorry!
No problem - hadn't tried it yet anyway. All of this is helping me understand a little bit more. Just glad someone else did the trigonometry for me and put it in a spreadsheet!
QQ-Box USB DVB-S Tuner - Unknown Device?
DVB-S2 Tuner Card for PBS
