thanks Radar - I'll certainly give that a try but I'll stick with the amalgamating tape for the dodgy roof top ones. Why people want dishes on rooves when there are no trees I will never understand, like they are 20 ft nearer the sat!
Yesterday I finally got the dish mounted on the barn, I followed the instructions that came with the GG-2100 motor, pointed the dish to azimuth 191 magn. (True south) for my location 43N 77W and 0 the motor. I didn’t touch the elevation cause the motor and dish are set per manual and assumed that’s the right settings, I ran about 25 feet of rg-6 to the Fortec receiver and a TV I keep in the barn, well got the motor to move but didn’t pick a single bird, maybe the true south setting are off, I’m hoping to play with it more sometime this week, I have a question about the LNBF that came with the package, it’s a Dream Star FTA-S2 standard dual linear I/P:11.7-12.2GHz. O/P 950-1450MHz, L.O 10.75GHz, N/F 0.4dB, it has two male plugs I used 1 and capped the other was that the right way to do it? Should I upgrade the LNB to something better? I tried to get help from the people I bought the system (incredible FTA) sadly they don’t know much about the stuff they sell. Once again thank you to all .
I have a question about the LNBF that came with the package, it’s a Dream Star FTA-S2 standard dual linear I/P:11.7-12.2GHz. O/P 950-1450MHz, L.O 10.75GHz, N/F 0.4dB, it has two male plugs I used 1 and capped the other was that the right way to do it? Should I upgrade the LNB to something better?.
Looking at the mounting pole on your setup, it seems to me that is slightly bent. Did you use a bricklayer's level to check if your Mast is perfectly vertical?well, changed the LNB type also moved the arm closer to the dish and still nothing I'm about to pick a rifle and use the danm thing for target shooting.
Valdelocc,
First rule first, make sure that your mast is perfectly plumb! Any small error in this will throw all your other angles and your tracking of the arc off.
I think your true south should be 192 degrees, but I don't know if you could ever tell the difference with a compass between 191 and 192. I doubt your compass is that accurate.
Mount your motor with the motor tube facing as near as you can get to this south angle.
I don't know what your motor manual stated to set the motor latitude angle or your dish elevation angle at.
But, I calculated 43.0 for the motor latitude (that is easy because it is always the same as your site's latitude).
I calculated 23.4 degrees for you dish elevation.
I would set all these angles and then...
Enter 43N and 77W in your USALS menu as your site coordinates or antenna position.
Pick satellite 79.0W AMC 5 so that your motor drives to that satellite. It should only cause your motor to move 2 degrees to the west.
Select TP 11.900 GHz, H polarity, symbol rate 2.170 from the TP list on this satellite. If it is not listed, you will have to enter this information manually.
Then, loosen the motor clamps (just enough so that you can rotate the motor on the mast) and rotate it very slowly east or west while you monitor the signal on your receiver's display of the signal level / quality or an analog signal meter until you pick up a high signal reading.
When you do, check to see if you are on the appropriate satellite. If the receiver does not have a sat ID table cabability, you will simply have to scan that satellite and see what channels you acquire.
If you pick up the channel KTEL, then you are definitely on 79 W AMC 5. This is a Spanish only channel, but a very very strong signal, so an excellent one to start with. If you are a Spanish speaking person, you may really like it.
I selected satellite 79W for you as it is very close to your longitute or due south and the channel KTEL, which is on TP 11.900, happens to be extremely strong (at least for me). I read it with a quality level of 98% on a Coolsat 5000. I am near Omaha, NE and I imagine that there won't be an extreme difference between your location and mine (at least without looking at the EIRP maps on Lyngsat).
If you are very patient and dedicated, you should pick something up in this manner. If you pick up something, try to peak the signal as best you can by gently grasping the dish from behind and pulling it slightly upwards, downwards, and to the right or left while you monitor the signal quality or signal level. Loosen the hardware and move the dish elevation or the motor azimuth slightly in the direction that improves the signal the most.
Always leave the motor latitude setting at the site latitude setting. SG-2100 motors are accurate here and you can trust this scale to be reliable measure.
AcWxRadar
valdelocc, not sure about your other settings but I think you need to change your "LNB Type" to Standard 10750, instead of "Univ LNB (9750,10600)".
Something else caught my attention while analyzing my pictures I think I mounted the LNB arm the wrong way, I’m not 100% sure but I think the arm goes inside the bracket and I mounted outside closer to the motor.
That may be an optical illusion because of the camera angle (not the photo I selected above), but I would certainly check it.
In the fifth photo, the one I have picked out from your post just above, I would put a level on the motor bracket and double check at least that (both sides), this will ensure that it is plumb from east/west direction. Also check the mast itself in the north/south direction.
AcWxRADAR
You may be right, but my comments were based on the attached photo below.
AcWxRADAR
