What software version do you have? (Press Menu twice). I've only seen L610 going to the 722 receivers.
You must go to movies by yourself .... and not spend any extra money when you're there.I'd rather spend my $6.99 at a movie theatre. Sorry Dish.
No, only to 722 receivers and I didn't look close enough, it may be only to a limited number of those.L610 is going out to both 622 and 722 receivers?
It's part of the new "truth is whatever you want it to be movement"Yes, but I can also change wikipedia to say that componate cables are used to make a chicken dance in a French circus.
It doesn't mean that its right or not.. But because wikipedia says it is it must be true.While I'm not disputing the claim, I am disputing wikipedia because the information can easily be changed by other people to support invalid claims.
.And HDCP is all about how to force more $$$$ out of consumers. Right from the same quality HDMI cables that sell for $49.95 at B/B or $39.95 at Wal-Mart being available for only $11.95 at Monoprice to eventually having to pay for each and every viewing of HD program and probably archiving fees to keep them on external HDDs. Trust me, you'll eventually even loose some of the DVR features we've come to enjoy with HD programming.<snip>....Remember when Dish put out a technical bulletin to installers telling them to always use HDMI/DVI when possible because someday component connections would be stripped down to 480p ? That was all HDCP-related........
Go ahead and change it then... In many cases, the people who author those entries will be set up to receive notifications if someone changes the information. Admittedly, that still doesn't mean the information is accurate....I am disputing wikipedia because the information can easily be changed by other people to support invalid claims.
Bigger questions are: 1) will dish display 1080/24p at full 1080 x 1920 resolution? (unlikely since Dish carries no 1080i at full 1080 x 1920 resolution); and 2) what will be the maximum bit rate? I've seen peak rates on Blu-ray of 45Mbps, and Blu-ray also has the ability to use VC-1 (a more efficient video codec than MPEG-4), so the claim by Dish that their 1080p service will be of Blu-ray quality is total nonsense.
The Dish 1080/24p announcement is about 95% marketing hype.
Only those with HDTVs that support true 24fps will be able to take advantage of it. These TVs display at some multiple of 24Hz (23.976Hz to be technically correct) such as 48Hz, 72Hz, 96Hz, or even 120Hz in some cases. The benefit is that the display rate matches the native 24fps rate of cinema, eliminating the uneven cadence due to reverse 3:2 pull down, reducing panning judder.
Fact is, component cabling is technically capable of carrying 1080p signals.
3) 1080p120 (or other multiple of 24) with broken reverse 3-2 pulldown
I don't believe any displays fall into category #3.
How can you expect the folks in this forum to take your post seriously, if it is based on education and experience and you don't even obliquely reference the use of Google and/or Wikipedia?This electrical engineer/computer engineer/computer scientist with multiple degrees and 20+ years experience in developing hardware and software for still and motion imaging applications agrees.....
