I need some help to get a more consistent signal if possible. I have dish 722 with ota, my zip is 32547 I can get all but fox out of mobile / pensacola. I have the following setup http://www.solidsignal.com/prod_display.asp?PROD=AD-DB8 ,http://www.solidsignal.com/prod_display.asp?PROD=10G212, http://www.solidsignal.com/prod_display.asp?PROD=DGCBL100, my property is about 40 feet above sea level and I recently raised my antenna up to about 45 feet, My problem is that most of the time I can get good signal strength on abc , cbs, nbc, pbs between 70-100 but sometimes during the day and early eve I will get alot of fluctuation and lose the signal mainly on cbs and nbc. at other times during the day these will be 75 -95 even up to 100. Is there a way to fine tune my set-up by adding something that will boost it more so I won't get any dropouts? thanks for any help
