As stated, don't forget there is also an Events limit.
With the exact same timers on the 722 and no programming changes with the upgrade, how could I have hit an events (or timers) limit on the hopper and not the 722?
96 timers or 576 events are the limits. whichever you hit first.
voripteth said:I think the real problem is that skipped programs are still considered events. If you record shows that are repeated often that event limit can get used up fast.
My guess is Dish put the event limit to keep processing fast. They really need to refactor their software to solve this in a different way. Events should just be actual recorded items. Skipped shows and shows saved during PTAT should not count against the max number of events.
I avoid those like the plague. The first time a scheduling time slot change occurred on a program and my timer was skipped with "Incorrect Event", I switched over to Dish Pass. I shouldn't have to revert back just to avoid an "anemic" event limit. (Good choice of word, 3Halo)You can also dramatically reduce the number of events by selectively using weekly, daily, or M-F timers.
Your choice, but the event limit is what it is, and there are many programs that can be reliably recorded with weekly, daily or M-F timers. You only hurt yourself by not using them to avoid excess events. I don't really care one way or another - what I suggested works a lot better than hitting event limits.
I am getting an error 41 on the hopper (or connected Joey) when trying to add a new timer. I only have 33 timers setup. The max should be 96, correct? Anyway, I went ahead and deleted a couple because it said to add a new one I should delete one. Well now I have 31 timers and I still receive the same message that I cannot add a new timer. Anyone else having this issue or anyone find a way to fix? I have tried resetting the hopper and that did not work. I also contacted dish and gave them the software version and such I am on and they are looking into it but not sure when it will be addressed.
I have a 2 hopper, 3 joey setup with a sling adapter.
What are new limits for the max number of events and timers?
Can you please check again with S221. We have made fixes to the max timer/events and it should allow you to set more timers.
Vivek
DISH
The limit is 96 Timers, or 576 events in the daily schedule, whichever comes first
