I have a Kingdome in my motor home. I recently changed it for HD and got a 211K. When I ran a check switch, it found 110 and 119, but not 61.5. King tells me it's the receiver, but it works fine in the house hooked up to my antenna there.
I want to test the antenna by hooking up my 722 and running a check switch. If there is something wrong with the antenna, I won't be able to see all 3 satellites. If I can see all 3 with this receiver, the problem is with the 211. The 722 has some sort splitter that hooks one coax wire up to both inputs. Can I hook one input from the Kingdome to the splitter?
There is a second connection for the Kingdome in the bedroom. Do I need to use that one for the second tuner?
