I just installed a pole mount for a 4ft ku dish and once the cement cured i noticed that the pole is turning.Is there anyway i can fix this or will i have to dig up the cement and set another pole.Is there any way to stop the pole from turning?
i will give that a try.well, one way I can think to fix it:
Can you add more cement at the top (where the pole meets the ground)?
If so, you can always place a long bolt through the pipe and cover it with cement. When it dries, it shouldn't turn anymore
That should prevent you from digging up the pole too.
Sort of off topic:
Is there a standard for mast size (dia) and depth for certain dish sizes.
i.e. The 4 ft dish, what size mast and how deep must it be in the ground. How high up from the ground is the dish mounted.
I guess I am wondering it there is a chart or list that shows this for different dish sizes.
