I bought it new several months ago, but am just now getting around to trying to set it up. I have only tried to hook it up to my old analog TV via CVBS RCA cable. I'm not sure I know how to set my digital TV up to work with HDMI. I don't understand about the component, or composite?
Yes! that is what I am trying to use. The Red White and yellow RCA connections.? I also dug up an old HDMI cable I still had from when I had from when I had a subscription to Direct TV and tried hooking it up to my digital TV with that. I still get no picture that way either. I'm not sure I was able to reprogram the digital receiver to work with HDMI though.
I am getting confused. Right now I am hooked up to the digital TV through the HDMI cable. But it is still getting the over the air channels. Do you mean I should switch back to the red white yellow RCA then do the VFORMAT thing? I am going to try both and see what happens.
...Is it necessary to upgrade flash the firmware now? If so is there an up to date one that I can download here?
