jack03332 said:
System Traxis 3500
Wineguard 2076
Univ lnb
sg2100 motor
how do i get my motor to track sats ? I can manually do it by pushing the button on the motor.
thanks in advance
Mount your pole or pipe 100% plumb , in both direction . Mount your motor to the pole . Set the motor angle to your latatude . Mount your dish on the motor arm , 100% " straight " so the motor and dish are pointing in the same direction .
If your dish has a reliable looking elevation scale , set the dish elevation acording to the chart that should have come with the motor , for due south . This adjustment will be fine tuned latter .
Hook up your coaxes , with the receiver off . Hopefully you hav a signal meter , if not , hopefully your receiver will display signal , even before you scan for channels .
If not , this is the one and only time I reccomend loading a channel list .
Go to the menue to set up your due south sat . Look in your menus for an option for USALS motor control . Type in your longitude & latatude & save that info . Tell the receiver to move to the position for that sat .
Move the receiver & TV outside so you can peak the dish / motor .
Turn the dish / motor assembly to your best guess of due south ( true - geographic , not magnetic - compas ) .
If you have a channel list loaded , choose a channel for your due south sat . Watch the signal strength and quality . But , you are hunting signal quality , that is what gives you a picture .
If you have no channel list , watch the sat signal indicator function or your sat meter .
Tweek the dish / motor assembly east & west , in small , tiny amounts . Do the same for the dish elevation , but leave the motoe - mount bracket latatude alone .
If you get a picture on your due south sat , tweek to as close to perfection as you can get it .
If you have gotten this all right , tighten everything down .
Now select your west most sat . Does it work ? May need to change the menue setting to Diesq 1.2 settting and use the motor east - west function to tweek it in . Give this sat a number position and save .
Do the same for your west most sat . Repeat for all the sats you are interested in .
Wyr
