help with hd setup
piglette
just upgraded to hd just had regular dtv.... now when im installing the triple lnb dish is there anything i need to know do i just find 101 and the other 2 line up?????
thanks :D
Elevation, direction, tilt
thanks :D
Triple LNB dishes have a tilt angle. If you put your zipcode into the receiver, it will tell you what the tilt angle should be in addition to direction and elevation. I just recently installed a triple LNB dish myself and had to fine tune the tilt to line up all three. I did not get it perfect yet. I have B and C at 94, but A is at 80.
You should be able to check the strength of all three sats.
ESPN2-HD Launch Rumor
NJ resident in need of MSG HD and FSNY HD!
