Thanks, I appreciate your time but my only issue is the pattern of signal I posted a few messages back, that's the strange part I can't figure out, unless those transponders are just too weak to get in Central CR! But still the pattern to me is very strange. In my 25 years I've never seen that!
My conclusion is that the problem is on the antenna quality, you are free to think on other issues, but don't forget I told you the problem is antenna gain.
You have some levels probably on the double powered transponders but if you want to get all the CONUS beams you will need more antenna gain.
Good Luck!!!
