I need some help in tuning my local channels - please. I have done standard dish pointing in the past with no issues, but recently switched to Dish HD (brand new) and then got my own 722, and my own HD (1000.4) dish via Craigslist - they both function fine, I just can't find the local stations as I can only get ONE satellite via the "Point Dish" screen. Here are the facts, and hopefully someone can tell me what I need to do to fix my situation.
* I have a Dish 1000.4 - verified that in the setup screen- however - I am unsure whether I have an Eastern Arc or a Western Arc LNB?
--------------there are three LNB's on the end of the arm -two together, and one on its own. There are three coaxial cables coming from the LNB to the end of the arm - two of them are together, and one seperate - I assume it is the two LNB's bringing down the two fused coax cables together, and the LNB on the right has it's own coax coming out.
* I am located in zipcode 17067 in Pennsylvania. My dish is pointed due south. I have no issues picking up the EchoStar 72.7 West - good verified reception with zero obstructions.
* I installed the dish using "ONE" of the three coaxial cables. It is running directly to the back of the receiver (722K).
* I can receive all the HD and non HD channels that are in my package EXCEPT the locals.
* I am able to use the dual tuner feature - i.e. PiP, other TV's in the house etc.
* I am relatively confident that I need to find satallite 62.5 for my locals?
The question is how?
Do I need some sort of a splitter? Do I need connect all of the coax cables coming from the dish into a splitter, and then send it to the receiver? Do I have my dish pointed incorrectly?
I tried, all weekend- hooked it up in all sorts of variations, ran a check switch each time- and no matter what configuration I use - I am not able to get my locals.
I have searched this forum, and some other searches on the net, and get bits and pieces but I guess my problem is- without knowing what I am doing in one answer leads me to guessing- which is of course not a good road to travel.
I Thank anyone in advance - genuinely - for their help with my problem.
I can upload images if needed, but I am hoping this is something simple a newbie is overlooking...
