what are the differences of the classic na and the mercury II and which one is good for a beginner in fta?
A DirecTV multiswitch will work fine with a FTA dish/LNBF and receiver. You will need a dual-output LNBF in order to use it though. Also, the OTA input on a 3 x 4 multiswitch will function, and allow you to use a diplexer inside to split the satellite and OTA signal.
is there a way to run a direct tv receiver and a FTA receiver from 1 coax cable
can an fta dish go into a direct multiswitch and then the line be split in the house using a separator?
even with the new mpeg 4 equipment from direct tv
But here the question is, "can I save a coax run into the house?", as I understand it.
- no -
And to that, we give a resounding, "hell no!".
Neither from dishes to switch, nor from switch to receivers.
For all sorts of reasons, you should keep your DirecTV and FTA coax wiring separate.
Clarification -
