I have been working with Executive CSR with a HD upgrade. While I have suffered the same delays and missed appointments upgrading to a SuperDish and 510+811, I have been getting great support and assistance from one particular executive CSR rep.
My only problem is I need a four sat set up to get locals, regular programming, plus CBS-HD. As many of you know, CBS-HD is only available on the wing sats 61.5 or 148- at least that is what everyone has told me.
To get 4 sats you need the vaporware 4-way switch called DP44. Long promised but never delivered by E* I emailed tech support with the following message:
I am a current subscriber with a 811 promised on the 27th of January. I just
had a SuperDish install for local stations on sat 105.
A big feature of HD for this household is getting CBS-HD. Yes we do qualify
and currently subscribe to distant locals. I understand CBS-HD was NOT moved
to the 110 sat with the rest of HD programming. I am quite willing to put up
another Dish to get 61.5 sat but I understand the following:
1. CBS-HD MAY move to 110. If so WHEN???
2. Get reception from 4 sats I need a DP44 switch. When will it be
available? I was told last December it would be available in mid January.
Its now January.
3. Is there any other method to use with a DishPro System to get 4 channels?
Here is the reply:
Dear Mr. Allen,
Thank you for your email correspondence.
In doing some research, CBS-HD does come from satellites 61.5, 105 or 148. I accessed your account, and you qualify for a second dish must carry, which is of no cost to you. This means some of your local stations come from the 61.5 satellite. If you would please call 1-800-333-3474, an agent will be glad to assist you in scheduling an installation.
Sincerely
Tom H.
What gives? Is this just wrong information? CBS-HD on 105????
Also, does any one know of a proven work around to the above problem of needing to get channels from 4 channels? I currently use a DP34 switch.
Rick
Its now January.
Here is the reply:
Dear Mr. Allen,
Sincerely
Tom H.
Rick
