Hello all -
I recently upgraded my HDTV to a plasma panel, and used the occasion to switch from component cables to HDMI. While using a lower grade HDMI cable, all was well. Then, within a matter of minutes of getting my display mounted and using a newer, higher grade HDMI cable, all of a sudden the HDMI input quit working.
I know it's been discussed here before the poor quality of the HDMI inputs on the 622, but this was rediculous. Before I pull out the 622 and call to have it swapped out, do the newer units have any better luck with the HDMI input? My AV Reciever is using the new cables just fine, as is the plasma panel. It's just the 622 that seems to have a problem.
Thanks for any input!
Jeff
Jeff
