card server?
can we use this box as server? i mean can we connect this box with other dreamboxes?
regards
regards
thank u for the reply, BTW..sorry for my wrong question!First, it's NOT a Dreambox, I don't know why that's in the description.
Second, we don't do card sharing here.
my advice is , before upgrade any clone s/w, first take the full dump of the original box after if flash corrupt then we can recover the box by the original flash dump!I may try later.
I am first going to see if I can Load the proper Firmware via RS232.
Then try the Channel Editor.
If that is successful, I may load the AZ firmware.
Is a Full Dump anything different than downloading the existing Firmware via RS232?first take the full dump of the original box
full dump means "full firmware and s/w" stored in "flash ic" , if any thing wrong happened cozed by clone s/w then ur box will not boot any more...after that u can program the flash ic with already taken flash dump file then ur box will recover again!Is a Full Dump anything different than downloading the existing Firmware via RS232?
Similar to "JTag"?BTW, u can read and store the dump file from the flash ic via "lab tool" only!
Would this be the same channel editor used in the Traxis DBS3500 (aka AliEditor) ?Lpraderi -
Thanks for the info. Maybe we can use the channel Editor and Loader.
That I don't know, I don't think I ever used the editor for my Traxis.Would this be the same channel editor used in the Traxis DBS3500 (aka AliEditor) ?
...It's kinda flaky but it does work with the 3500
Just tried the Traxis Editor and it does not work with the files I saved from the Sathawk.
But it is encouraging it's uses a similar file format, so we may see some updates.
Any of the Editors allow the PIDs to be changed? Manual PID entry seems to be missing in the Sathawk, which is needed for a few channels.If you want to try different channel editors
Also, the Sathawk does not allow the use of a Motor and Switch, can any of the other units do it?
I believe the Traxis units are Ali based. I've read that the early firmware had same issue with Motor and Switch.If you know some Ali based STB who can work in such a setup please point me to
his firmware
