OTHER GTMEDIA V7 or V9?
I beg to disagree. The GT Media boxes give more than you pay for. My goodness, I only paid $30 delivered to me for a V7S5X. I paid $215 for my Edision Mio+ (plus shipping). Which is best? I never answer that question about anything. Each has its own capabilities.
The GT Media has a rapid accurate blind scan. For this reason, I blind scan all the time: repeatedly each satellite, each day. The receiver is sensitive. Its streaming capability is pitiful. Its user interface is a little awkward but you get used to it. The Edision blind scan requires you to get food before starting so you don't perish while waiting. But...the Edision's streaming capability is excellent. The other features of the Edision make it a quality receiver worth its price provided you invest some time to learn it well.
I'm glad I have both boxes. I would buy either again without thinking further.
4.2.2.? I will never believe any consumer receiver will have that capability despite what its advertising may claim unless I see it for myself. For me, considering the rarity of 4.2.2. that I find, I can just stream the feeds wirelessly via wifi to my laptop and plug the HDMI cable back into the big screen. This is easy and works reliably.
Reactions: comfortably_numb
Check which firmware you have now. The latest is: V464_20231109
Just checked and there is a new firmware available for the V7S5X. v466_20241112 is the number but when I unzipped it and read the instructions it says to use Hungarian language??? Anyone installed this?
Just saying.................
Just checked and there is a new firmware available for the V7S5X. v466_20241112 is the number but when I unzipped it and read the instructions it says to use Hungarian language...
I haven't installed it. But I'm pretty cautious about messing with the firmware on these lower cost boxes. I'm nervous you may not be able to go back if the newer firmware doesn't work well. Are there any notes suggesting the new stuff will make it function better?
Just checked and there is a new firmware available for the V7S5X. v466_20241112...
You got me curious. I tried loading this firmware and got the message "upgrade failed". I tried a couple times using All Code and Main Code methods. So I tried the previous V465 version. Same results. I don't know if I'm doing it wrong or this firmware isn't compatible with my hardware.
cyber did you ever get that v465 version to load and work on your V7S5X again?
I upgraded successfully using the v466 version. It seems to be the newest firmware for V7S5X. You can now select Hungarian as an audio language if that's useful. Other than superficial menu heading changes, I don't see any difference. Maybe they just fixed some bugs.
Reactions: Lone Gunman
Would you please share with us the reason you think it didn't work the first time you tried to load it?
Good question. I don't know. Op error? Flaky receiver? Flaky firmware? All I know is I used my standard method for troubleshooting: keep trying. Persistence works when genius is lacking.
I should add I tried to go backwards to v464 and that failed. Again, not sure why. But v466 works fine so I'm happy.
After getting my new V9 reciever, boy it's scan fast in normal mode or switch to accurate scan and still run little faster than my old Edison receiver!🙂👍
So far looking and a wonderful surprise is does have U.S. Closed Captioning and European Subtitles systems!😎👍
Now I have a question any good legal apps that is compatible with V9 and can be downloaded directly in V9 or I have to download from phone or desktop computer? :hungry2 :):hatsoff
What channels have you verified the CC to work on the V9? You can PM me if needed :)
OTHER GT Media V9 Prime DLNA Function
