Well its a beauty.. The scaler ring itself was very tight on the DSMI Int. C/KU combo LNBF. While it does fit, I ran into another issue that the LNBF holder was increadably tight on the LNBF. I could fassen it on but I couldnt adjust the skew from there. Loosing it would only make it so the screws would fall off and then the holder would pop out of the LNB. When I did try to adjust for Skew it broke the LNB holder. Yikes. Also, the LNB holder would not fit on my Fortec Star as the neck was too small for the arm of the dish.
When I did have it up I was useing the DSMI INt C/KU combo LNBF. I could not get it to pick up any C or KU band. This is the worst LNBF I have seen. I was expecting it to pickup alot of KU and some C. That didnt happen. Swaping out my KU lnbf to the C band one they looked like they had the same focal point. On my meter I was pegged on signal, around 80 percent with no quality. No matter how I pointed the LNB weather it was at the 12, 6 or 9 oclock positions it would not pull in any quality.
Fortunatly, I do have that one LNB that Anole recommended to me from Satav on its way as soon as they ship it. I made sure I got a holder while i was at it just in case and I'm glad that I did.
