Maybe this is your problem?
Figured I give you a good laugh maybe, I know problems like this can be real frustrating.![]()
It's funny because he actually told me maybe an animal was resting on it or something. Hahahahah
Question: is there any good way to narrow down the LNB as being the culprit in circumstances like these?
Yep!
Replace it with another one that you know is good, and see if it works. Short of owning some expensive test equipment, that's about the only and best way...
Ha! Hopefully they'll let me return it if the first one turns out to be good. The installer will probably go nuts and charge me another $90, which also sucks. And now this whole thing that should have cost me about $150 will end up costing me damn near $350. Sucks.
Does this even sound like it could be an LNB issue? It almost sounds like a wire issue to me, which the tech suggested. I'll try changing the wire from the wall to the box, but will have to wait to replace the wire from the LNB to the wall.
One month later, no equipment has been changed, no tech call and still doing the same thing? Yep, time to try something...
Agreed, the longer that this is put off, the more likely the equipment wont be swapped or the tech to return... Hurry!!!!![]()
