Let me totally confuse you now. I first asked about what I wanted to do with my new 722 and the DVD/VCR's. I want you to know what equipment I have and let you determine what I should do to get this stuff hooked up. If you could be so kind. Here goes.
Vizio 32" LCD TV== 3 HDMI--DTV/TV--RGB PC--COMPONENT 1 & 2--AV1/S-VIDEO--AV2--1 OPTICAL (OUT)--1 ANALOG (OUT)
Samsung Digital Home Theater_ HT-Z310--HDMI (OUT)--COMPONENT (OUT)--OPTICAL AUDIO (OUT)
IMPACT ACOUSTICS_ 3-PLAY COMPONENT VIDEO DIGITAL AUDIO SELECTOR
TOSHIBA D-VR3SU DVD/VCR RECORDER (WITH COMPONENT AND OPTI AUDIO)
SAMSUNG DVD-VR300 DVD/VCR RECORDER (WITH COMPONENT AND OPTI AUDIO)
DISH NETWORK-- DVR-722
I have an OTA antenna with a booster and rotator also.
I hope this doesn't confuse anybody. I am, but I'm just learning the ropes. I sure do appreciate the help.
Lyle
Yep, that certainly changes things. The home theater system will not handle video switching, only audio, and you only have three audio inputs available
Aux1: mini-din on front panel
Aux2: RCA on rear panel
D.In: Optical
As you already found out, you will need that 3 play component video/audio switcher. It appears to have optical and analog audio in as well as component video in and out.
The Samsung dvd/r vcr only has composite/analog audio inputs
The Toshiba is so old, I can't find specs. Assume it is also only composite inputs.
I am going to make the assumption that you want to use every source, and minimize your switching. Thus, you are going to do the bulk of the switching (but not all of it) with the switcher box.
Start at the TV. Connect the home theater DVI output to the HDMI Input1. Turn off the TV speakers in the configuration screen. Connect the component output video from the switchbox to the component 1 input of the TV.
Next, connect the optical output of the switchbox to the optical input of the home theater.
Connect the 722 component outputs to channel 1 component input. connect optical output to channel 1 optical input.
Same for Samsung DVD/VCR to channel 2 component video/optical audio of the switchbox
Same for Toshiba DVD/VCR to channel 3 of the switchbox
Connect composite video output and analog l-r from the 722's TV2 output to the inputs of the Samsung DVD/VCR
Connect the composite video output and analog l-r from the 722's TV1 output to the Toshiba DVD/VCR.
Connect the antennas as described above.
If you MUST get audio from the TV tuner, connect l-r audio outputs from TV to the AUX-2 input of the receiver.
Most of the time, you will leave the TV in component 1 input. This will provide complete switching for the 722 and both DVD/VCRs. If you want to watch the DVD player in the HT system, you will need to switch the TV to HDMI and the home theater to AUX2.
Most of the time, the home theater will be set to D.In and you will switch audio with the video. Exception is when you want to watch the DVD (DVD position) and audio from the TV (AUX-2)
Heaven help you if you decide you need a Blu-Ray player. You will need to give something up.
[Editorial Mode ON:] Folks, this is why I constantly argue against HTIB systems. There simply isn't enough connectivity to do this cleanly and the poor family has to live with some complicated switching. This could be greatly simplified with a good HT receiver, such as a $350 Onkyo 606. In this case, everything would have connected to the receiver with a single HDMI output and all switching would have been accomplished with a single button push on the receiver. [Editorial Mode: OFF]
Finally - Lyle, I am actually going to be in LaCrosse this weekend to officiate at a sports car event. I am tempted to offer a visit. PM me if you want to work something out, and I'll send you my cell number.
