Well I received the projector today. Set it up and turned it on for the first time to begin the setup and configuration of it. Then after 2 min of use the bulb blew. I guess I will just have to wait a few more days to play around with it.
If I had an extra lamp and mine had just blown... it would either be working or toast by now
Ahh, I see now!
1. use digital video essentials to correctly set the white and black levels.
2. ensure that you sit far enough back not to see the pixels / screen door effect. If this is not possible, slightly defocus your PJ to blur out the pixels.
frkn amazing isnt ??
Have a look at the graph in this postDo you think that 20 feet is plenty far enough back.
The "in the action" experience when sitting close to the screen (i.e. having a large field of view),
can "compensate" for some imperfections you might see in still images and will hardly notice while watching movies.
I have seen the previous generation Panasonic twice (two evenings).If you can see the SDE, or pixel structure... you are sitting too close or you need to defocus...
On a 800x450 resolution screen it takes a split second to differentiate between a SD and HD feed.If one was to use this logic you could say, just watch SD satellite...
From what I've seen this "defocusing" is already done by the manufacturer. And you can't undo it.
I don't know what they do and what it is called.On the Panny AE 500 / AE 700 and AE 900 series units it is not done by the manufacturer.
