Well, even after 2 1/2 years of pointing dishes, tuning signals, running cables and hooking up switches, even I can do some "D'OH" things (I'm blaming the heat)
Friday I hooked up a FTA box in the computer room with the 4LNB combo (G4 C-Band, G10, SBS6, Nimiq1) and everything was fine but the signal on 11720 would cut out and pixelate real bad. Sometimes it wouldn't even lock. The rest were fine
Saturday 11799 would have dropouts and pixelation. So I thought maybe bad cable...nah everything else works fine. Listened to Power 97 for 2 hours yesterday with no issues and watched G4 nets with no issues.
So tonight I hook up my Pansat in the living room and G10 was LOW (45 on 11799 and really low on 11720) and G4 was low (45)
Well folks, today in Minneapolis it hit 100 and at 9:00 it still was 87. The G4 dish was easy...there is a board between the cable spools and that got shifted (we had 30mph winds). Pounded that vertical...bam 75 on nets
So now I work on G10. Swapped LNB's and nothing...same thing. So I decided to "flex" the dish (lean into it). Well I went to lean into it and the dish moved all right.
Yep. Last time I was working on it (Friday) I only finger tightened the top bolt and didnt even tighten the lower bolt. So the 30+ mph winds we have had kept jostling the dish.... D'OH!!
Tightened it down and we're back in business
