My motorized Birdview unit with the "621" LNBF is feeding C-band to both 4D unit and to my Pansat 3500 via single cable. Ku band not hooked up yet. C-band Pansat FTA has been WONDERFUL! I've had to change polarities with the 4D, and want to get away from that, and use 4D only for positioner, thus making FTA easier in scanning and enjoying.
Last night, I decided to finally let the Pansat power the LNBF directly, bypassing the 4D's signal path completely, and directly wire the C-band portion of the 621 LNBF to the Pansat, thus controlling polarity from the FTA Pansat receiver, and no need to switch polarities via the 4D. (still using 4d for positioner until Gbox gets installed.) Seemed logical, and an easy "next step" in the ongoing Birdview conversion to FTA.
To my surprise, I was unable to get any signal on the Pansat when directly wired. Kept horizontal channel's signal tuned-in for the switchover, (Ion network feed) but got no signal when Pansat is fed directly by the C-band side of the LNBF. When put back on the power-passive splitter, with 4D powering the LNBF, all goes back to "normal" on the FTA!
Its as if there is no voltage on the LNBF output from the Pansat, but measured 18 volts on coax going to LNBF, and the picture is restored when returned to the 2-way power passive splitter, with power supplied by the 4DTV's LNB power supply.
Do I have a polarity issue needing re-scanning (somewhere I read that the 4D and FTA polarities are reversed)...or is there something else? The polarities as listed on various sites, I thought matched from 4d to FTA as I scanned them in. The 4D is on W1, transponder 300 when the system is functioning as a pair.
There is no option to turn the LNB power on or off in this model of Pansat in any menu I can find...and, would obviously need power in any case, so I think with the 18 volts, the absence of power is not the problem.
Does the Ku side of my LNBF need to be hooked up and the diseq be put in place on this receiver for C-band to work once it's stand alone? Doesn't make sense to me....
I'm "old hat" at C-band, new to FTA as we know it today and, to Ku.
Perhaps this info and the two pictures will help? The pictures are when fed through the 4D and splitter, not when direct to the LNBF.
I'm grateful for any ideas, and not afraid to sound like a rookie on this one!
Thanks again for a great site! (and especially the polite attitude shown by users!)
