Scott Greczkowski said:Currently there is no way to Diplex in an OTA signal using DPP technology.
BTW I am told that a Quad DishPro Plus LNB is still a ways away from being released. We will see the twin LNB a long time before we will see the quad.
Why can't a diplexer be used with DishPro Plus?Scott Greczkowski said:Currently there is no way to Diplex in an OTA signal using DPP technology.
OTA ----------. .-------------------------->
V |
DPP34 ----> Diplexer -----/ /----> Diplexer -----> Separator ----->
Can you elaborate on this.Scott Greczkowski said:Currently there is no way to Diplex in an OTA signal using DPP technology.
bcshields said:<skip>
Not sure about the 921 and I'm pretty sure the 721 isn't. Someone will need to check out the back of the 921 to see if it says DishPro Plus.
<skip>
You're probably right - considering the labels on the separator.mike123abc said:No you cannot use the separator to feed two different units, only two feeds on the same unit. This was stated by Dish, and if you think about it, there is a good reason. The reason is that there is no way to control what satellite feeds are coming down the cable from two different reciever. A single reciever can signal the DPP44 which two signals it needs (even the same signal 2x) down the cable. Two separate recievers could not coordinate this.
SimpleSimon said:You're probably right - considering the labels on the separator.
However, they COULD have provided 2 control channels - one on each port.
It looks to me like DiSEqC would allow for this - but maybe Dish didn't take that path. The separator could "move" the second ports commands to a different band that the DPP switches were expecting. Of course, this would mean that the separator would have to be more than a simple block converter - which is what I'm guessing it is.
The question that we'll probably never have an answer to is why they didn't - or for that matter how the thing actually works in the first place.
Who knows, and I'm just speculating here.
I believe you are mistaken. The separator eliminates the need for a 2nd RG-6 to feed the 2nd tuner. Single mode won't help that in the least.bcshields said:I'm thinking the 721 is too old, and hasn't production stopped?
Besides, you basically get the same functionality on the 522 when the software gets updated for 1 tv two tuner usage.
Given their history, that's probably how E* thought about it. But if you add some smarts to the separator, the receiver wouldn't need to know which port it was on - the separator would translate regular commands to a different place and the DPP switch would be looking for them there.mike123abc said:Who knows (just speculating again) they would probably have to add a menu option to all single tuner boxes to tell the box that it is the "B" unit, causing it to use the "B" controls (provided there are now two control channels). But, then even more problems will pop up since people will have trouble thinking why their legacy stuff will not work over the splitter too, probably too much effort, easier to just get it working in 2 tuner boxes and forget about it.
