N.B. These PC techniques only copy, but cannot play back, programs archived on the EHD.
Thanks for this info, llokey and TheKrell. I successfully copied all recordings from my old 500 GB external USB hard drive to a 1 TB external USB drive using a LiveDVD of Knoppix Linux. I've never used Linux before, and my first try with Ubuntu liveCD Linux wouldn't mount the drives, but Knoppix worked on the first try. The external hard drive file system seems to have changed since this thread was discussed in 2012. There's was not a DishArc folder on my external drive, just two mounted partitiions showing up as sdb1 and sdb3. I formatted the new drive with my receiver, then copied all files from the old drive's sdb1 and sdb3 partitions to the new drive's partitions that were named sdc1 and sdc3. Plugged in the new drive and everything came up and worked fine.Yes, you can clone the drive using various utilities, regardless of the file system (which is ext3). But I prefer booting up a Linux LiveCD, plugging in the external drives which auto-mount, and then dragging/dropping the DishArc folder. I've done it using two previously-formatted disks, and it works. I also tried mounting the partitions on Windows using ext2ifs, and that also worked.
And whatever happened to sdb2?
