I'm having a major problem with my external hard drive and I'm hoping someone here can offer some tips.
My external drive has been working fine for some time. Friday night we had a power failure and the drive was on. Saturday evening I wanted to watch one of the shows I have stored on it and the receiver did not recognize the drive and wanted to format it.
I wasn't too worried because I've experienced this in the past and it's always been easy to recover. I hooked the drive to my Linux server and backed it up like always. I then returned the drive to the Dish receiver (ViP 622) and let it format.
Here's where my problems began. It wouldn't format the drive, telling me that the format had failed. I took it back to my server and deleted the partitions, then hooked it back to the DVR. The format worked fine. Just to make sure everything was fine, I recorded two minutes of the show I was watching and copied it to the drive. All was fine. I could watch the show and copy it back to the DVR without issue.
For a sanity check I then powered off the drive and waited about 5 minutes then turned it back on. The drive was never disconnected or moved. The DVR wanted to format it again.
Long story short, the DVR will sometimes format it and most times fails. When it succeeds, and I turn the drive off and then back on without disconnecting it or moving it and it wants to format it.
I've checked the drive on my server, copied files back and forth to it and from it and there are no errors. I've tried a second smaller drive and I get the same problem with the DVR.
I'm hoping someone here can offer some help.
Thanks.
Thanks.
