dvr/record plus on 522
Akash
Hi guys...new to dishnetwork/dvr/the forums
Anyways, the question i had was that i want to be able to specify which tuner (tv1/tv2) to use to record certain shows using the guide....is there any way to do this?
example, the daily show is shown on comedy central at 10PM everynight mon-thurs. Using the guide can i set this to record to TV2 so that on TV1 i can watch something else.
I am in dual mode using 2 tvs (1 upstairs, 1 downstairs).
thanks for the help :)
This is what record plus does on the 522, it allows you to specify which tuner you want to record the DVR shows if there is only one event to record at a specific time. By default if you activate the record plus it will record to tuner 2 if there are no other events to be recorded at that time so that you can watch what you want on tuner 1 live at the same time.
Needing help with Dish Network problem
pixalation problem
