Well after some research based on the zip you sent me; having the test outcome in your favor might be your best bet if you say you can't receive signal. It seems based on a small amout of research, you should be able to get everyone, but FOX via OTA. One local affiliate denying you is owned by LIN.
I really wish I could see your topography and your OTA setup. I have seen some really inexpensive OTA setup done in the CA mountains pull digital OTA very reliably from 35+ miles away and just can't ID why your will not.
Let us know how it all works out, be sure to document and post so others can learn from your process; post screen shots IF you get the to provide waivers.
Ok, from the get go I have told them I have NO HD signal and NO SD channels except for one CBS channel, and that is a fair picture, in winter when the trees are bare.
There is nothing inexpensive here. I've got over $500. (materials only) into my antenna system. Top of the line Channel Master deep fringe vhf/uhf antenna, Top of the line Channel Master UHF antenna, both with antenna amplifiers and a digital Channel Master rotor, 30' mast on my barn, guy wires, dual down leads, etc etc.
I'm going to try to enclose a url showing my antenna system as I was putting it up. If you get the first picture you'll see I was interrupted by 3 bears, a 3 legged mother and two cubs. I have to look out all the time. I was working under my truck one day and I almost asked a bear to hand me a wrench.
Fox is a total no signal at all here.
Now, imagine a 1400ft hill, that goes down to 1050ft or so and then back up to 1400ft on the opposing ridge about a mile away. Also, to the North another ridge approximately the same height, and to the South, not quite as bad but I'm in the middle of a very large forest (1,000 acres looking SSW).
My house is located 1/2 way down the first ridge I mentioned, at 1250ft elevation. All I see, looking in any direction is hills or trees. The picture of the "road" is hard to show perspective. The pic is looking straight across to the other ridge and 1/3 of the way down the hill where the picture was taken.
Anyone got a spare 200+ tower they want to lose?
