DPP Twin with DP Dual setup?
DishBacker
SatelliteGuys Guru
132
DFW Area
Has anyone successfully utilized a DPP Twin LNBF with a DP Single/Dual connected to the Sat In input within the DPP Twin LNBF to support either 61.5/148?
I got a DPP Twin for my 921 / 501 setup a couple of weeks ago and installed it without a hitch, now I'm looking to add a second dish to look at 148 and finally get CBS-HD from a second source (can already get it from OTA, but it never hurts since only 1 OTA can be used at a time).
Since DFW has a local still on 148, I can get the free install, but just wanted to see if anyone else has luck with this setup before I go through the install process and/or pain that might come with it.
Installed my 148 Dish today with a DishPro Dual LNB. Worked like a champ with my DPP Twin using the Sat In connection. On a side note, anyone in the DFW area currently utilizing the 148 bird? I peaked out my father in law's satellite strength tester, but I can only get about 85 Max when doing the point dish test. Has been a pretty crappy weather day, rain and all, so could have a little effect on it.
Also, calling dish to get the channels on that bird active, namely CBS-HD, sure is a pain. Took the lady a good 15 minutes to get it worked out.
Which receiver? 811 0-100 or 921 0-125?
I peaked my 148 to over 105 (921) on transponders 11 and 12. I got like 117 on tuner 1 for one of them, really hot. Not different on 110/119.
I am west of you so that should help me.
I couldn't help 110/119 -- near 100.
Now, OTA-wise, an outside antenna helped a lot. A 10 dB amp gave an additional 10 points except for one already over 120. My big problem is NBC (4/26 in Albuquerque) that fluctuates 20 points in mid-news.
-Ken
921 DVI #2/2 (#1 7/9/04 lightning nearby) 120B/F051/L211HECD-N
811 Component #1/1 (1/04)
501 RF/S-vid #2/4 machine (#1 few months, #2 flakey, #3 1 day, #2 came back, ran #2 + #4 until kept quieter, running for 2 years)
Versions: current software
Monitor: Hitachi 46H83
Dish: 500/500 Legacy SW64. Power inserter on 811.
Orbits: 119, 110, 148
Rim antenna replaced by underdeck old 78" or more antenna. Still in line of sight. It is diplexed at SW64 on 811 line.
Dish is discriminating against old customers!!
721 Acquiring Signal
