Okay so I have a little dilemma going. Just got a 722 receiver, this now gives me 4 receivers all dual tuner all being fed from a DP44 Switch using DPP Separators. Everything has been working fine. I got the new 722 a couple days ago and hooked it up, activated it and added HD to my programming, everything worked great the first night, then last night when I went to watch the 722 it said there was a problem with my switch. I did a check switch on the 722 and it kept coming back with errors and was not able to detect the DP44.
In the meantime my other 3 receivers contiued to function as normal with gread reception on all of them, so it definetly wasen't my switch. I had 2 extra DPP Separators so I proceeded to try each of those on the 722 and encounterd the same problems with all 3 separators. I then hooked up the 722 without the separator using 2 runs of cable from the 44 switch to Sat 1 and Sat 2, reran check switch and perfect, no errors, detected the switch and everything runs perfect.
My questions are, is it likely that 3 brand new DPP separators that I tried are all bad? At this point should I just buy another DP44 Switch and cascade it off the first one and run two runs of cable to the 722? Anyone have any ideas why individual cable runs work perfect but yet it won't work with a Separator. Also why would the 722 work fine the first night with a Separator then stop working with one?
Sorry for the wall of text, anyhelp would be appreciated.
