Currently I have a DP Plus 44 looking at 61.5, 110, 118.5 and 119. Can anyone point me to a diagram to stack another 44 switch onto my current one? I want to add a fifth satellite 129 into my current setup. Thanks in advance for any help you send.
Here is an example of how this stuff works:
You have to have a dp21 for each tuner that you would like to have 5 satellites on. In other words, you can have a dp21, one for each of the 4 ports exiting the dpp44. Maximum of 4 tuners, unless you have trunked into the mix another dpp44, which would give you 8 tuners.How would you split the signal from the 5th sat local so that mult dp21's can be used?
Oh, I see what you're saying.
If the 5th lnb is a dp dual, you're good for 2 dp21's, but if you're wanting more, there would have to be a way to "split". I think that what you are asking is probably uncharted territory, but possibly do-able.
